Add Incorrect Links between Two Spines
The following sample output configures invalid links between spine devices:
NH-1(config)# interface Ethernet 0/13-15
NH-1(conf-if-eth-0/13-15)# no shutdown
(efa:user)user@dev-server:~$ efa fabric show --name fab3
Fabric Name: fab3, Fabric Description: , Fabric Stage: 3, Fabric Type: clos, Fabric Status: configure-success, Fabric Health: Black
| IP ADDRESS  | POD | HOST NAME |  ASN  | ROLE  | DEVICE STATE |     APP STATE     | CONFIG GEN REASON | PENDING CONFIGS | VTLB ID | LB ID |
| 10.20.246.1 |     | NH-1      | 64512 | spine | provisioned  | cfg refresh error | LA                | INTIP-C         | NA      | 1     |
| 10.20.246.2 |     | NH-2      | 64512 | spine | provisioned  | cfg refresh error | LA                | INTIP-C,INTIP-U | NA      | 1     |
| 10.20.246.3 |     | NH-Leaf1  | 65002 | leaf  | provisioned  | cfg in-sync       | NA                | NA              | 2       | 1     |
| 10.20.246.4 |     | NH-Leaf2  | 65002 | leaf  | provisioned  | cfg in-sync       | NA                | NA              | 2       | 1     |
| 10.20.246.5 |     | NHF-Leaf1 | 65001 | leaf  | provisioned  | cfg in-sync       | NA                | NA              | 2       | 1     |
| 10.20.246.6 |     | NHF-Leaf2 | 65001 | leaf  | provisioned  | cfg in-sync       | NA                | NA              | 2       | 1     |
CONFIG GEN REASON:
LA/LD - Link Add/Delete, IA/ID/IU - Interface Add/Delete/Update, PLC/PLD/PLU - IPPrefixList Create/Delete/Update
MD/MU - MCT Delete/Update, OD/OU - Overlay Gateway Delete/Update, EU/ED - Evpn Delete/Update, PC/PD/PU - RouterPim Create/Delete/Update
DD - Dependent Device Update, DA/DR - Device Add/ReAdd, ASN - Asn Update, SYS - System Properties Update
MD5 - BGP MD5 Password, BGPU - Router BGP Update, BGPLL - BGP Listen Limit, POU - Port Channel Update, NA - Not Applicable
PENDING CONFIGS:
MCT - MCT Cluster, O - Overlay Gateway, SYSP - System Properties, INTIP - Interface IP, BGP - Router BGP
C/D/U - Create/Delete/Update, PA/PD - Port Add/Port Delete
For App or Device Error/Failure reason, run "efa fabric error show" for details
For config refresh reason, run "efa fabric debug config-gen-reason" for details
--- Time Elapsed: 83.368638ms ---
(efa:user)user@dev-server:~$ efa fabric health show --name fab3
Fabric Name                             :  fab3
Fabric Type                             :  clos
Fabric Health                           :  Black
 Fabric Status                          :  configure-success
 Fabric Level Physical Topology Health  :  Green
Fabric Device Health
| IP ADDRESS  | ROLE  | CONFIG STATE HEALTH | OPER STATE HEALTH | DEVICE HEALTH |
| 10.20.246.6 | Leaf  | Green               | Green             | Green         |
| 10.20.246.5 | Leaf  | Green               | Green             | Green         |
| 10.20.246.1 | Spine | Black               | Red               | Black         |
| 10.20.246.2 | Spine | Black               | Red               | Black         |
| 10.20.246.4 | Leaf  | Green               | Green             | Green         |
| 10.20.246.3 | Leaf  | Green               | Green             | Green         |
--- Time Elapsed: 37.140239ms ---
(efa:user)user@dev-server:~$ efa fabric health show --name fab3 --detail
Fabric Name                              :  fab3
Fabric Type                              :  clos
 Device IP [Role]                       :  10.20.246.6 [Leaf]
  Device Health                         :  Green
  Configuration State Health            :  Green
    Dev State                           :  provisioned
    App State                           :  cfg in-sync
  Operational State Health              :  Green
    Cluster Health                      :  Green
    Physical Topology Device Health     :  Green
    Underlay Topology Device Health     :  Green
 Device IP [Role]                       :  10.20.246.5 [Leaf]
 Device IP [Role]                       :  10.20.246.1 [Spine]
  Device Health                         :  Black
  Configuration State Health            :  Black
    App State                           :  cfg refresh error
  Operational State Health              :  Red
    Physical Topology Device Health     :  Red
    Device physical topology errors
| SOURCE NODE IP | SOURCE NODE ROLE | SOURCE NODE POD | SOURCE NODE INTERFACE | DESTINATION NODE IP | DESTINATION NODE ROLE | DESTINATION NODE POD | DESTINATION NODE INTERFACE |      ERROR      |
| 10.20.246.1    | Spine            |                 | 0/14                  | 10.20.246.2         | Spine                 |                      | 0/14                       | incorrect-links |
| 10.20.246.1    | Spine            |                 | 0/15                  | 10.20.246.2         | Spine                 |                      | 0/15                       | incorrect-links |
| 10.20.246.1    | Spine            |                 | 0/13                  | 10.20.246.2         | Spine                 |                      | 0/13                       | incorrect-links |
 Device IP [Role]                       :  10.20.246.2 [Spine]
| 10.20.246.2    | Spine            |                 | 0/14                  | 10.20.246.1         | Spine                 |                      | 0/14                       | incorrect-links |
| 10.20.246.2    | Spine            |                 | 0/15                  | 10.20.246.1         | Spine                 |                      | 0/15                       | incorrect-links |
| 10.20.246.2    | Spine            |                 | 0/13                  | 10.20.246.1         | Spine                 |                      | 0/13                       | incorrect-links |
 Device IP [Role]                       :  10.20.246.4 [Leaf]
 Device IP [Role]                       :  10.20.246.3 [Leaf]
--- Time Elapsed: 51.504456ms ---
